Learn How To Fix The Issue ‘my Dell Laptop Will Not Turn Up’.
Hi, if you have the issue ‘my dell laptop will not turn up’, then check when you plug the charger to your system will turn on or not. If it turns on, remove the charger and battery and press the power button for few seconds and reconnect your battery and charger. If your system turns on it is well. If not If your laptop is beeping, then there is a problem of processor failure in your laptop, in that case, change the motherboard or processor to fix this problem.
If you have a Dell laptop and it won’t turn on, check if the charger is connected properly to the laptop and to the AC outlet. Most laptop chargers have an LED indicator. Check if the LED indicator on your charger is activated. It is usually a green LED indicator. If the LED indicator is activated, that means there is power on the charger.
If the charger has power but the laptop won’t turn on, try removing the battery. Disconnect the charger from the laptop then open the battery compartment at the bottom and remove the battery. After this, connect the charger to your laptop and press on the power button to turn it on. See if this works. If your laptop turns on, there is a problem with your battery.
The battery needs a replacement. But if the laptop still won’t turn on even after doing this, there is a problem with its power supply. In this case, you need to bring it to a Dell service center for proper servicing. Normally, with only the charger connected and the battery removed, the laptop should turn on.
