Hello everyone,
I have accidentally deleted one of the partitions from my device. I have no idea how to recover it now. Does someone know how to recover deleted partition on a system? If yes, please reply.
Learn How To Recover Deleted Partition Easily
Follow these simple steps and your partition will be restored:
1. Step 1: Scan your device’s Hard Disk for the deleted partitions.
You can easily scan your hard disk space to search the deleted partition and later retrieve data from it.
2. Step 2: Select the deleted partition and open “Restore Partition” dialog
3. Step 3: Set the restore options in “Restore Partition” dialog box and run restore.
The restored partition and the corresponding Logical Drive both will appear in Recovery Explorer and in Windows File Explorer under the drive letter you have assigned.
