Learn How To Resolve Outlook Not Getting Emails Problem
Hi, I am using Outlook 2006 on my computer, but it starts giving an error now. I am facing the problem of outlook not getting emails in my inbox. How can I fix this?
1. You can check your junk folder to check if you find your missing email over there.
2. Alternatively, you can Check your inbox filter and sort settings.
3. Check that mail is not in your clutter folder.
4. It might also be possible that you have added the sender to your blocked list.
5. Also, check if your email inbox is full and you need to delete few emails.
If you use Microsoft Office Outlook as email client but you are not receiving any messages, check that the account you created in Microsoft Office Outlook is configured with the correct IMAP or POP settings. You can get these configurations from your mail service provider. For Yahoo! Mail, here are the correct IMAP and POP settings:
For IMAP:
For POP:
