Learn How To Resolve Playstation Error 80010514 In Brief.
I wish to know about the playstation error 80010514. If someone has some idea about them, then please share your views regarding the same.
Thank you.
Thank you.
First, put your PS in standby mode.
Then, hold the power button until the system turns on and then off.
Once again, hold the power button: it will beep after turning on, and then it will double beep. As you hear the double beep,remove your finger from the power button immediately.
Now, plug in your controller via USB and press the PSbutton.
Now, click on the option RESTORE FILE SYSTEM.
Finally, it will restart, and a screen will come up reading Corrupted Data. Your PS will replace this data. Then choose to continue. It will solve your error.
Error code “80010514” in Sony PlayStation 3 means “The PS3 system was unable to read the current disc.” This indicates a problem with your game disc. If you receive this error when playing a game, eject the disc and clean the surface of the disc with a soft clean cloth. After this, insert the disc back and try again.
If this doesn’t work, try loading a different disc in the console and see what happens. In case the second disc loads successfully, your first disc is probably damaged that’s why it cannot load. You probably need to replace it.
On the other hand, if the second disc or any other disc you try doesn’t load, you probably need to bring your PlayStation 3 to the nearest Sony repair shop to service it.
