Learn How To Resolve Samsung Error Codes 4E.
My Samsung Washing machine is displaying an error 4E before it starts its cycle. The Samsung error code is 4E. Please tell me how to fix this issue ASAP. Thank you in advance.
The Samsung error codes4E/E1/4C all are related to the problem of water supply. To resolve this, you have to check that the water taps are opened and connected properly. Also, there should not be any clogging in the water hoses. Sometimes, this situation also arises if water taps are frozen, so make sure that this is not the case. Ensure that the Washing machine is operating at sufficient pressure.
In Samsung washing machines, you may receive error code “4E” or “4C” if there is a problem with the water supply. This error code is triggered and displayed in the panel when the washing machine detects a problem with the water supply. Among the reasons that can trigger this error include:
To fix the problem, follow these troubleshooting:
Notifications
