Learn How To Troubleshoot Outlook 2007 On Your PC
I am facing problem in my outlook 2007 work space in sending and receiving emails. How do I troubleshoot outlook 2007 error?
This error occurs when you do not have a proper internet connection, did not install the latest updates, .ost files and .pst files of Outlook stored on the drive do not have sufficient storage and many other reasons. To resolve this error, first of all, check your internet connection. If it is not working then probably poor connection is the reason for it. Check your username and password on https://sso.secureserver.net/?app=email&realm=pass, if they are registered and working correctly. Verify the hostname of the servers.
Maybe the port you are using currently is blocked by the Internet Service provider due to some security issues, so refer changing the settings of your SMTP port:
Still, if it doesn’t work, inform on Customer Support.
If you have a problem with Microsoft Office Outlook regarding sending and receiving email messages, the first thing you should check is the settings of your account. If you created an IMAP or POP3 account, make sure the mail forwarding settings are correct like the SMTP or outgoing server, incoming server for IMAP or POP3, their respective port numbers, and security protocols used.
You can fetch these settings from your mail service provider like Google, Yahoo, FastMail, GMX, and others. To get these settings, log in to your email account using your web browser then go to the help section. Search for the IMAP or POP settings.
Once you verify that these settings are correct, the next thing you need to check is the username you entered in Office Outlook and the password. The username is your email address and the password is the password you used to log in to your email account.
