Learn How To Turn Off Alarms: Outlook Shared Calendar Reminders
Hi. I would like to know about Outlook shared calendar reminders. How can I turn off the alarm reminder? Also, tell me about the reminders in a secondary calendar. Please suggest steps for the same. It will be a great help. Thanks in advance.
Answered By 0 points N/A #180356
Hi. The steps to turn off the Outlook shared calendar reminders are as given below-
1) The remainders can be turned off in the pst files
2) On the top level of the data file, right-click on it and click on properties to change the setting
3) There will be an option of Display reminders and tasks from this folder in the to-do bar on the bottom of the screen which needs to be unmarked so that no reminders are received. The reminders will get enabled once the check box is marked.
4) However, if the flagged items want to be kept, and only the calendar reminders need to be deleted then, you can create a custom list.
Secondary calendar reminders:
The reminder can be turned off by clicking on file>options>calendar
Then set the option as only on appointments that need to have reminders
Hope we helped.
