Learn How To Turn Off The Firewall On Your Computer.
Hello, I have been trying to run my program. But it does not work correctly as it is conflicting with the firewall. I tried turning it off, but couldn’t. Can you please tell me how to turn off the firewall on my Computer?
Answered By 0 points N/A #80190
To turn off firewall, follow the below steps:
1. Click on the Start menu on the bottom left, click on search and type ‘Windows firewall’. Pick up the option with the same name that comes up in the result.
2. The panel would show few options. There would be a left sidebar shown in the panel, click on "Turn Windows Firewall On or Off".
3. After clicking, you will be able to see "Home or Work Network Location Settings", click onto turn off Windows Firewall. This will help you turning the firewall off from your Computer. In case, you might want to turn it on again. Click for turning on Windows Firewall button above it. Hope this was helpful.
Thank You
