To Learn Hp System Recovery From Windows 7.
Hello, My system has a normal booting right now, I need to do the hp system recovery from Windows 7 in the easiest way. Can you help me out, please?
You can start the recovery quick and easily in following steps:
1. First, you need to shut down your computer and disconnect all devices and cables if connected.
Also, you might want to delete media or other personal documents internally from the drives. Monitor, printer, and other hardware instruments should remain connected.
2. After doing, turn on the computer.
3. Go to start->All Programs-> Recovery Manager, again click the Recovery Manager.
4. Under the column names “I need help immediately”, click on System Recovery.
5. A message will be prompted by the Recovery Manager asking if you want to keep the original condition or restore it.
Click on YES followed by Next.
6. The Recovery Manager window will appear if the recovery partition is functioning correctly.
7. Click on System Recovery again.
8. Select a backup option, if prompted by System Recovery to back up your files.
9. Click on OK, and later on, Finish when the system recovery is complete.
Complete all the setup procedure and wait until the system restarts.
10. As soon it is complete, turn off your computer and plug in all your devices that you disconnected earlier.
11. Update and protect the system, also reinstall any anti-virus for the security.
Notifications
