Learn More About The Ink For HP 6520 Printer In Easy-To-Follow Steps
Asked By 15 points N/A Posted on -
Hi. I am not very comfortable with the computer-related hardware and software. I want to know the steps to replace the ink for HP 6520 printer. Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #116265
Hi. The steps to replace the ink for HP 6520 printer require you first to ensure that the power of the printer is on. Then, to remove the cartridge, first, open the access door of the carriage. Then, remove the cartridge from the slot by pulling it up. Next, the new cartridge can be inserted by removing the package from the new cartridge and then twisting the cap so that it comes off. Next, slide the cartridge into the slot and press it until it falls into place. Then, close the access door of the cartridge followed by aligning the printer for a good quality of the print.
Hope we helped.
