Learn online about free pub to PDF converter
Hi. I would like to know about the software free pub to PDF converter. What are the steps of the conversion? Thanks in advance. It will be very helpful.
Hi.
The steps for free pub to PDF converter are as follows-
1) Visit the website Online2PDF and browse the file which needs to converted, edited or merged.
2) The formats excluding PUB which can be converted are Word, Excel, PowerPoint, Images, and Publisher etc.
3) The protection on the PDF is removed automatically if any. The correct password is required for unlocking the document
4) Click on the convert option
5) The maximum size of the file which can be converted is 50MB. If there are more than one files, then the file size must be less than 200MB.
6) You can select 20 files at once
Hope we helped.
PUB or “.pub” is the file extension used for documents created with Microsoft Publisher, a desktop publishing application included in Microsoft Office suite. It is a proprietary format that is not widely supported. With Microsoft Publisher, you can create, publish, edit, manage, and share content. PUB files can be opened with Corel Draw X4 and Adobe PageMaker but they can’t be edited.
If you have several PUB files that you need to convert to PDF, try these two:
