Learn The Steps About How To Connect To T-Mobile Hotspot
Hi. What are the steps to be followed so as to learn how to connect to T-Mobile hotspot? Your response is awaited. Thanks in advance. Please reply ASAP.
Hi. The steps which need to be followed to learn how to connect to T-Mobile hotspot are as given below-
First connect the computer using Wi-Fi to the mobile hotspot that you create. Next, either enter “mobile.hotspot” on your web browser’s address bar or double-click on the T-Mobile hotspot admin icon on the desktop of your PC. Then, enter the credentials in the fields provided and click on login option. However, of it is your first time logging onto the admin page then, first select the next option on the bottom-right of the page following which click on next option again after reading the tip that is provided to you. Type the password and then click on enter. Then, select a new name for the mobile hotspot and click on enter. Enter a new password using which you can connect to the hotspot to make it more secure and click on enter. Then, reboot the mobile hotspot and select the refresh option on the admin page.
Hope we helped.
