Learn The Steps To Export Ad Users To CSV
Hi. I am a non-IT person and I don’t have any technical background. I need to export the files from active directory to CSV. How to export ad users to CSV? Please reply ASAP. Thanks in advance.
Hi. To learn how to export ad users to CSV, a CSV generator tool can be used. First, click on the CSV generator tool to start it. Next, from the list, click on the AD object type following which browse the CSV file and import it in the name field of the file. To get all the file attributes, click on generate. In case the CSV file is to be stored in a different location, select the export option. In case the CSV file is needed with additional attributes, select the Advanced option and then select the attributes from the list appearing on the dialog box.
To include the attributes in the list, click on add. The field names can be removed by clicking on delete. Then, select finish and if the list needs to be displayed then click on generate. To save the file, select export.
Hope we helped.
Notifications
