Learn The Steps How To Add Signature On Word
Hi. I am using MS-Word. How to add signature on Word? Can I please know the steps in advance? Thanks in advance. Please reply as soon as possible.
Hi. To learn how to add signature on Wordfollow the steps as given below-
1) First, open MS-Word
2) Click on the Insert menu
3) Then select the signature line option
4) Let the setup window appear
5) Complete the fields such as suggested signer, suggested signer’s title, etc. Then click on OK
6) A signature will appear on the bottom of the page
7) Select the signature and then right-click on it
8) Then, from the options, click on sign
9) Then select the option of select image and choose the image which you want as your digital signature
10) Browse it from the PC and then click on open
11) Select the sign option
12) In the signature confirmation window which appears, click on OK
13) The signature can edited and deleted as well from the options which appear on the right-side of the window
14) Click on signature setup
15) Delete the signature by clicking on the remove signature option
Hope we helped.
Notifications
