: Learn The Steps How To Burn A Powerpoint To A DVD
Hi. I want to learn how to burn a PowerPoint to a DVD. Please let me know the steps which are to be followed to do the same. Thanks in advance. It is urgent so please reply ASAP.
Hi. To learn how to burn a PowerPoint to a DVD,
1) First insert the DVD into the PC. The DVD should be blank
2) Check that the DVD has been identified by the PC by clicking on start and then my computer. Make sure that the icon appears there
3) Then, click on the restore button to minimize the window
4) Select the PowerPoint presentation and right-click on it to copy it and then paste it on the drive
5) Format the disk if needed and give a new name if asked for
6) Wait till the formatting is done completely
7) Wait for the presentation to get copied on the drive
8) The file appears translucent because it has not been burned yet
9) Click on the burn option to ensure that the presentation gets copied to the DVD completely
10) You can also choose a name and the burning speed if offered 1
1) After the process gets completed, the disk will be ejected automatically completing the action
Hope we helped.
