FidanoskiF
Posted on - 08/05/2016
Hi. I would like to know the steps as to how do I play MOV files? Which is the best media player for the MOV files? What are the steps to convert MOV to Windows media player compatible formats? Thanks in advance.
Learn The Steps As To How Do I Play MOV Files
Hi. The steps which need to be followed as to how do I play MOV filesare as follows-
1) Select the start menu
2) Click on programs, then select QuickTime and click on QuickTime player
3) If the software is not available install the QuickTime software online
4) You can either browse the file or drag and drop it
5) You can also select more than one files to be played
QuickTime is software which is the best media player to play the MOV files.
The steps to convert MOV to Windows media player compatible formats are-
1) To the MOV video converter, add the MOV files which need to be played
2) Click on the format option to select the output format such as WMV from the format and video section
3) Select the convert button to convert all MOV files to the WMV files so that you can open them with Windows media player without any issue
Hope we helped.
