Learn The Steps How To Load Balance Web Servers
Hi. I have recently learnt about web servers. How to load balance web servers? Please reply ASAP. Your response is awaited. Thanks in advance.
Hi. To learn how to load balance web servers, first create the database of NSS if it does not exist already with the help of a command which must be typed in one single line. After this, whenever the password of the NSS database is asked for, enter the password. After this, the administration server should be started. Then, a certificate should be generated which must be self-signed. A HTTP listener should also be created following which the SSL should be enabled and the certificate should be assigned. The configuration must be deployed to the web server by entering the command to be followed and also following the instructions given in the plug-in related to the installation of the load balancer to install it effectively. Hope we helped.
