Hi. I am working on Excel these days. I am not very thorough with it though. I want to merge mails from Excel with Work. How to mail merge from Excel to Word? Please reply ASAP. Thanks in advance.
s.sency
160 points
Learn The Steps How To Mail Merge From Excel To Word
To learn how to mail merge from Excel to Word, first open MS-Excel and set up the file using tables and design it the way you want it to be. Next, prepare the main document which is to be merged. Then, mention the source recipient that is, the source of Excel. Then, select the recipients to whom the mail is to be sent after merging. Make sure that you have arranged all the content of the labels. The arrangement involves inserting the fields to be merged, changing the merged data’s format, formatting the fields using field codes. Next, after all the formatting has been done, save the document by clicking on file and then save. Once again, go through the labels and format the recipient list so as to refine it.
Then, after everything has been done, complete the merge by personalizing all the labels individually if required, printing the labels and saving them for future use also.
Hope we helped.
