Learn The Steps To Install Admin Pack For Windows 7
The steps which are involved to install Admin pack on windows 7
1. Download the Admin pack for Windows 7 from Microsoft site according to your system byte.
2. After downloading RUN the Software.
3. Start the installation.
4. Press yes for installation
5. Successfully installed, on the next screen you will be seeing each feature of admin pack tool.
6. Close the screen and go to control panel.
7. In control panel select Programs and features. Select Turn Windows features on or off.
8. Then select Remote Server Administration Tools .
9. Depends on the requirement you can select option.
10. This is Remote Desktop Services Tools which help to manage multiple remote desktop connections in Windows 7 computer. Press ok
11. The newly added pack tools will be found under Administrative Tools in Windows 7.
The other administrative pack tools which you select also will be listed under Administrative Tools.
