Learn The Steps To Install ADUC On Windows 7
Hi. I am not very comfortable with the computer-related hardware and software. What are the steps to install ADUC on Windows 7? Please reply ASAP. Thanks in advance.
Hi. The steps to install ADUC on Windows 7 require you to first download the remote server administration tools from the download centre of Microsoft. Next, the folder containing the downloaded package needs to be clicked twice so as to unpack it and then start the Setup wizard for the Remote Server Administration tools. Then, after all, the installation steps are completed, click on the finish so that the wizard can be the exit from. Then, click on start, control panel and select the programs. To open the Windows Features dialogue box, click on continue and then view all the options under remote server administration tools. Then, the tools to be installed should be selected after which click on OK. Then, display the administration tools icon shortcut on the start menu by configuring it by right-clicking on start, properties or clicking on the tab of the start menu and then clicking on customise.
Hope we helped.
