Learn The Steps To Install And Load The Analysis Toolpak
Hi. I am not very comfortable with the computer-related stuff. I need to know the steps to install and load the Analysis ToolPak. Please reply ASAP. Thanks in advance.
Hi. The steps to install and load the Analysis ToolPak require you first to click on the file and then click on options. Next, after clicking on the Add-ins in the manage box, click on the Excel Add-ins. Next, click on go. After this, the Analysis ToolPak needs to be selected from the add-ins available box and then click on OK. In case the ToolPak is not mentioned in the add-ins box, then browse it to navigate to it and then click on yes to install the software.
Alternatively, in Mac, click on Excel to start the software. Then, click on add-ins from tools and then to enable to solver option, select it and then click on OK. Then, locate the ToolPak on the data tab.
Hope we helped.
