A K Azad
35 points
Posted on - 09/10/2016
Hi. I am not very familiar with the computer-related hardware and devices. I would like to install the HP Deskjet 5150 colour inkjet printer. How can the installation be completed? Please reply ASAP. Thanks in advance.
Learn The Steps To Install HP Deskjet 5150 Colour Inkjet Printer
Hi. To install HP Deskjet 5150 colour inkjet printer, first try installing the driver with the help of a CD which is offered when the printer is purchased. Insert the CD into the driver, follow the instructions which appear on the screen to install the drivers. Alternatively, the driver can be installed by using a setup file. Download the file and once is gets downloaded, select the run option. Then, after selecting the printer, click on OK.
Further, select the accept button. Then, select the USB port to be used and click on OK. The third method can be of installing the driver using an add device approach which consists of extracting the file which has been downloaded as the first step. Next, click on start and select device and printers. Next, add a printer and select a USB port for the printer. Select the have disk option and finally click on OK.
Hope we helped.
