Learn The Steps To Install The HP Officejet Pro L7680 Ink
Hi. I am not very good about the software and hardware related stuff. How to install the HP Officejet Pro L7680 ink? Please reply ASAP. Thanks in advance.
Hi. The requirements to install the HP Officejet Pro L7680 ink are that you need to make sure that the computer as a CD/DVD drive, the disc for installing the printer is needed which must have come along with the accessories and connect the printer with a USB cable.
The steps are-
First turn the computer on and navigate where the printer is to be installed. Next, until and unless you are asked to connect the printer to the USB, do not go ahead.
After this put the CD in the PC and execute the setup file after which the installation wizard will begin. Then, end it by following the instructions. In the process itself, you will be prompted to connect the PC with the printer using the USB cable and once the printer is detected, go ahead to the next step which is to input the values in the wizard so that the driver is installed successfully. After this, prints can be taken out from it.
Hope we helped.
