Learn The Steps For The Installation Of HP Officejet 8600 Pro Drivers
Hi. I want to learn how to install the HP Officejet 8600 Pro drivers. What steps need to be followed? Please reply ASAP. Thanks in advance.
Hi. The steps to install the HP Officejet 8600 Pro drivers require you first to gather all the setup items which are required such as the name of the network, password, computer which is connected to the wireless network and the wireless printer. Next, ensure that the printer, router and the PC have been switched on and then disconnect any USB cable which is connected to the printer. Next, connect the printer to the wireless network by opening the control panel, clicking on the setup icon, clicking on the network, wireless setup wizard and then continue.Â
Next, select the name of your network from the list and click on OK. In case the name of your is not present, enter it and then click on OK. Enter the password as well. Then, install the driver by turning the printer on, going to the download page and then select the download option.
Hope we helped.
