Learn The Steps For Installing HP Deskjet 3520 Ink Cartridge
Hi. I am not very comfortable with all the computer-related stuff. I want to know the steps for installing the HP Deskjet 3520 ink cartridge. Please reply ASAP. Thanks in advance.
Hi. The steps to install the HP Deskjet 3520 ink cartridge require you to first take the printer out of the box and remove all the orange coverings before you proceed further. Then, connect the cord of power to the printer and then plugging it into the electrical outlet. Wait for the light to turn on. Then, load the tray with paper and slide the paper in the tray.
Then, wait for the cartridge to move in the center. Then, remove the tape from the printer cartridge and slide it into the cradle. Then, insert the CD into the computer which came along with the printer and install the software. Connect the cable of the printer after the installation gets complete. After this, the printer will be ready for use.
Hope we helped.
Notifications
