Learn The Steps For Installing HP Officejet Pro K8600 Printer.
Asked By 15 points N/A Posted on -
Hi. I am not very knowledgeable about computer-related hardware and software. I would like to know the steps to install the HP Officejet Pro K8600 printer drivers. Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #116257
Hi. To install the drivers of HP Officejet Pro K8600 printer, first, switch on the computer wherever the driver is to be installed. Next, do not connect the USB cable to the PC unless asked to. Then, download the setup file of the driver and then run it as the administrator by logging in using the credentials. Then, finish the installation by following the instructions appearing on the screen. Next, connect the USB cable between the printer and the PC when asked to. Complete installing the driver by inputting the value at each step and then you can begin with the printing once the driver has successfully been installed.
Hope we helped.
