D Wright
10 points
Posted on - 08/03/2016
Hi. All the programs get blocked with Firewall. I want to enable access to some programs using the Firewall. Please let me know the steps as to how to allow access through firewall? Please reply ASAP. Thanks in advance.
Learn The Steps To Know How To Allow Access Through Firewall
Hi. The steps to know how to allow access through firewallare as follows-
1) First build the sample program
2) Open the start menu and click on the run option after typing“firewall.cpl” in the search box. This will open the Firewall control applet window
3) To allow another program, click on change settings option
4) Click on Add program in the exceptions menu
5) Select the browse option and then click on the executable file of the sample
6) Then, click on OK option
Hope we helped.
