Learn The Steps To Know How To Get Rid Of Trojan Virus
Hi. What are the features of a Trojan and how to get rid of Trojan virus? What other ways can be used to remove it from the PC? Please reply ASAP. Thanks in advance.
Hi. Trojan is a malware which is downloaded from the internet as an infected file. It is a threat to the system as it can steal away the information and also infect it. This virus can be removed by installing firewall and antivirus on the PC. To learn how to get rid of Trojan virus, remove the virus I case any of the above-mentioned ways fails would be to remove the virus manually from the PC. The steps of which include finding out the file which has been infected by Trojan, disabling system restore so that the infected files which are being deleted do not get restored. Then, turn off the PC and start it again by selecting the safe mode. You can also add or remove programs in control panel to delete the infected files.
You can also remove the files from the system folder to delete all the files related to a particular program. Restart the PC in normal mode after that. Another way can be of displaying the files which were hidden and then starting the computer again but in the normal mode. Next, the processes which are associated with the Trojan should be stopped.
Hope we helped.
