Learn The Steps To Learn How Do I Open A MPP File
Hi. I have this doubt of opening an MPP file. What are the steps to be followed to know how do I open a MPP file? Please reply ASAP. It is urgent. Thanks in advance.
Hi. There are three ways to learn as to how do I open a MPP file including-
1) Kadonk live project
• Download the project viewer and install it
• After the installation gets complete,
open the viewer
• Select the file menu, then click on open project file and finally select the open local project file option
2) Housatonic project viewer
• Open the MPP file with the project viewer online
• To open the viewer, click on launch the Housatonic project viewer online free option
• Select the file menu and then click on open
• Navigate to the MPP file which needs to be viewed. Select view project option to open the file
3) Seavus project viewer
• Go to the website of the software to install a free version of the software to test it. A link for the same will be mailed to you
• Click on the download seavus project viewer link to download the software
• After the download completes, double-click on the software to install it on the PC
• Open the software and then click on file and open
• Browse the MPP file which needs to viewed so as to open it in the viewer
Hope we helped.
