B.makone
10 points
Posted on - 09/16/2016
Hi. I am not very comfortable with the computer-related hardware and software. I want to know the steps to load the ink for Canon Pixma PRO-1 printer. Please reply ASAP. Thanks in advance.
Learn The Steps To Load The Ink For Canon Pixma PRO-1 Printer
Hi. The steps to load the ink for Canon Pixma PRO-1 printer require you to first locate the access door and open it for the printer. In case, you do have any control over the access doors, the access panels need to be looked for and can be pulled forward so as to open them. Then, check the lights so that the empty cartridge can be located. The cartridge can be released from its slot once the tab is pushed above or in front of the empty cartridge. After this, the replacement ink can be removed from the box. Before opening the ink cartridges, make sure that they are shaken well.
Then, remove the cartridge from its wrapper and then twist the cap. Place the cartridge into the slot which is empty and then the lights will automatically turn on when installation is done properly. After the installation is done, the access door of the printer should be closed, and then the light will turn on after which the printing will begin automatically.
Hope we helped.
