Learn The Steps To Replace HP Deskjet 1050 J410 Ink Cartridges
Hi. I am not very familiar with the computer-related stuff. I have been trying to replace the HP Deskjet 1050 j410 ink cartridges since a long time but to no success. What are the steps for the same? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #88283
Hi. To replace the HP Deskjet 1050 j410 ink cartridges, first, turn the product on by pressing the power button and wait for it to become idle so that the procedure can be continued further. Next, load a white paper which is blank and open the access door of the cartridge. Then, again wait until the carriage is idle and then continue further. Pull out the cartridge to remove it from the slot that is allocated to it by pressing the cartridge so as to release it. Next, take the new cartridge out from its packaging and replace it with the old one. Insert the cartridge into the slot by pushing it till it is place. Then, close the access door of the cartridge and wait for about 30 seconds so that the page is aligned and then printing will start automatically. Hope we helped.
