Fraserr thor 0 points N/APosted on - 02/18/2017
I am a new user of iPhone, and I don’t have much knowledge about iPhone, neither am Iof a technical background. I need to see different time zones on my phone, but I cannot figure out a way to do it.Could you please tell steps to show two time zones on iPhone?
I am giving the steps below to show two time zones on iPhone, so that it will be easy to perform:
Go to Utilities folder
Go to clock application and then to the world clock
Add the second clock( you can add more clocks, as per your wish)
If you want to display the other clock(s) on your home screen then use ‘Clockify’. If you have new iPhone, then lucky for you Clockify has been upgraded and now works more smoothly.
If you want to see two time zones on your iPhone, you simply need to have two clocks. That means you need to add a second clock. To do that, on your iPhone, go to the “Utilities” folder then select the Clock app. After that, add a second clock and set the time zone different from the first clock.
World Clock Time Zones app
You can also install an app called World Clock–Time Zones. It supports iPhone, iPad, and iPod touch and requires iOS 9 or higher. With this app, you can have a large variety of cities to select from around the world. The time is synchronized from timeanddate.com to display the exact time.
The app automatically updates to the databases from timeanddate.com to support the changes in time zone information that happens around the world. The app offers a variety of analog clock designs which allows you to select between analog, digital, or text clock display type. It also allows you to select between 24-hour and 12-hour clock format.
With the app, you can conveniently find the correct local time for any location around the world.
1....
