Learn to convert Foot and inches to centimeters
What is the definition of the terms, FOOT, INCH, and CENTIMETER. How to convert from Foot to Inches, Foot to Centimeter, and inches to Centimeter?
INCH: – An inch is a unit of length that is known as an equivalent to exactly 25.4 millimeters. So, 12 inches form 1 foot, and 36 inches form 1 yard.
A foot (symbol: ft) is a unit of length in the imperial and US customary systems of measurement. One foot contains 12 inches.
An inch is a unit of length that is known as an equivalent to exactly 25.4 millimeters.1 in = 0.0833333333 ft
1 ft = 12 in.
For example,
convert 25 into ft:
25 in= 25 x 0.0833333333 ft = 2.0833333325 ft
CENTIMETER: It is a metric unit length that equals to 0.3937 inches
Now,
for converting foot to the centimeter,
1ft = 30.48cm
For example,
Convert 7ft into cm.
1ft = 30.48cm
7ft= 7 x 30.48 = 213.36 cm.
Now, for converting from inches to the centimeter,
1 inch= 2.54cm
For example,
convert 7 inches to cm.
7 inches= 7 x 2.54 = 17.78
Notifications
