Learn To Cover 0x80070013 Backup Error
Hi, I am Mehak. Recently I installed Windows 10, and while backup, I got stuck with 0x80070013 backup error. Can you help me to understand this issue, and what should I do to fix it?
During the backup update of Windows 10, you can face an error code knowns as 0x80070013 backup error. Even if you have successfully installed your Window, you can still experience the error at the beginning of execution.
It is known as Write error, appears in the popup window.
To fix the error,
1. click on the message and go to properties.
2. Select the Security tab and then select Advanced at the bottom.
3. Go to change and select it.
4. Type in your account name in the lower box and select Check Names.
5. Select the column and press, OK.
6. Select the box next to Replace owner on sub containers and objects and select OK.
7. Select OK to begin changing ownership.
Notifications
