Learn To Create A Microsoft Word Business Card Template.
Hi, you can easily create a Microsoft Word business card template. First, you need to open MS Word and there click on mailings and go to label then the below picture appears.
At label products section, select Avery standard option and choose business card number as of your choice in ‘product number’ section and click on ‘ok’. Then you will find new document option click on it. Then blocks will appear represented by lines as below picture.
Write anything as of your wish in provided space and if you want the same matter in other blocks you can copy the content of the first block and paste it to rest of the blocks. At the end click on print preview and check is everything is done well and then save.
