Learn To Fix Itunes Restore Error 3014 Instantly.
Hi all,
I am getting an itunes restore error 3014 on my device.
Does anyone have any idea on removing this type of problem? If yes, please reply.
Thank you.
Hi all,
Thank you.
Follow these steps to solve your problem.
Step 1. First, install and launch the program Dr. fone.
After that, run the software.
Step 2. Then, fix the iPhone error 3014.
From the dashboard of dr.fone, select ‘More Tools’ and then select ‘iOS System Recovery.’
Next, connect your iPhone/Pod/Padto your computer with a USB cable.
As soon as dr.fone detects your device, click the ‘Start’ button.
Step 3. Your task is over.
After downloading the software, it is great to see the repair going in progress.
Then, you will receive a message saying that the process has been successful.
Now onwards, your device will start and act normally.
