Learn To Install Microsoft Office Home And Business 2013
My computer has a RAM of 1GB. Will I be able to install Microsoft Office home and business 2013 on my computer? What are the requirements?
Yes, it is possible for you to install Microsoft Office 2013 but only if it is a 32 bit Operating System. If you have a 64 bit OS then you should have a minimum of 2GB RAM.
The requirements are as follows:-
1. The Processor of 1GHz or faster with SSE2 instruction set.
2. 3 GB or larger available hard disk space.
3. 1024×576 display resolution with DirectX 10.
4. Windows Server 2008 or 2012 32/64-bit, Windows 7 or 8 32/64-bit.
5. Internet Explorer 8, 9 or 10, Mozilla Firefox version 10.X or higher, Apple Safari 5 or Google Chrome version 17.X or higher.
6. 3.4, 4.0 or 4.5 NET installed.
That memory you have will depend on the version of Microsoft Office 2013 you’ll be installing. If you will install the 32-bit version of Office 2013 then that is enough but if you will install the 64-bit version of Office 2013, that is not enough and is below the requirements. Office 2013 supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
It requires at least 1 GHz or faster 32-bit or 64-bit processor with SSE2 support, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, 3 GB free space, video card compatible with Microsoft DirectX 10 and supports 1024 x 576 screen resolution, and Microsoft .NET Framework 3.5 or higher. If your computer has these specifications then you are good to go to install Microsoft Office 2013.
Microsoft Office 2013 supports the following web browsers:
