Learn To Resolve Error 1321 Setup Cannot Modify The File Instantly.
I was trying to install a Microsoft Office Professional Plus 2010 on my PC. The program stops responding, and then the error message pops up on the computer screen in the following manner:
‘error 1321 setup cannot modify the file. Verify that the file exists in your system and also, that you must be havingthe permissions to update it.’
I cannot even cancel the installation of the Office Suite.
Can someone tell me how to fix this issue?
Answered By 0 points N/A #293482
Following are few methods to solve your error:
Method 1: Disable the Encrypt Contents to Secure your Data
If you want to resolve this error, then make sure that the settings of encrypting contents to secure data are not enabled. For that, right-click the folder where you wish to install the MS Office Suite. Now, click on properties and then General tab. Next, go to Advanced option.
Now, in the Advanced Attributes dialog box, ensure that the checkbox Encrypt contents to secure data under Compress or Encrypt Attributes arenot enabled. If it is not, then uncheck to disable.
Method 2: Remove the Viruses from the system
The virus can also provoke error 1321. If this is so, then install and run an antivirus on your system. The antivirus detects all malicious viruses like malware, spyware,adware and Trojans. Then, remove them to fix the error.
