Hi!
I am facing this annoying issue where Quick Heal error code 1603 appears and crashes the running window without any warning! This sudden crashing has become quite frequent, and I have suffered a major data loss in past few days. Please help me resolve this issue ASAP. Thanks in advance!
Learn To Troubleshoot The Quick Heal Error Code 1603 In 9 Easy Steps.
Hi!
The displaying of message ‘error 1603’ is a symptom of Quick Heal error code 1603. It can occur while performing multiple processes such as installation, shut down, restart or while running a Quick Heal Technologies Ltd.- related software program(e.g. Quick Heal Total Security). You can solve this problem by following these simple steps:
Step 1: Repair any 1603 error code related registry problems using a recognized registry cleaner such as Win Thruster.
Step 2: Scan your PC for malware.
Step 3: Get rid of all the junk, temporary files and folders and cache in your PC using Disk Cleanup (cleanmgr).
Step 4: Make sure that all the PC device drivers are up to date with their latest versions.
Step 5: Go to ‘Windows System Restore’ and check for any unnecessary changes. If found any, UNDO them.
Step 6: Perform the process of installation again for Quick Heal Total Security program associated with error 1603.
Step 7: perform a check using windows system file checker (“sfc/scannow”).
Step 8: Update your windows to all latest available versions.
Step 9: Conduct a clean installation of your Windows OS.
Hope this helps solve your problem.
