Learn To Update To Jre-6u21-windows-i586.exe In Brief.
I have an outdated version of Java on my device, and I wish to upgrade my version to jre-6u21-windows-i586.exe.
Can anyone help me with that?
If yes, please reply.
Thank you in advance.
Just follow these steps below for doing the same:
That is a very old version of the Java Runtime Environment or JRE and that is not recommended because of the bugs and security holes. If you use 32-bit Microsoft Windows, the highest possible version you can install is Java Runtime Environment 8 because this is the last version of the Java Runtime Environment that provides a 32-bit version.
For users with 32-bit Microsoft Windows, download Java SE Runtime Environment 8. Here, two versions are available for download: 8u161 and 8u162. Download Java SE Runtime Environment 8u162 since this is the latest for JRE 8. If you use 64-bit Microsoft Windows, you can download Java SE Runtime Environment 9.0.4.
JRE 9 is currently the latest Java Runtime Environment and it is available only for 64-bit Microsoft Windows. You can also download the 64-bit version of JRE 8.
