Joan Terndo
Posted on - 06/09/2017
Hi, I am trying to translate a document in my PC from French to English using Microsoft Word translator. I am not proficient in computer skills, so I am having trouble figuring it out. Please help ASAP. Thanks.
amurphy
Learn To Use Microsoft Word Translator To Translate Parts Of A Document.
You can use the Microsoft Word translator to translate a host of different texts in your PC. You can translate an entire document, or simply use the mini translator to translate a selected portion of the text. First, you need to set a translation language. Follow these steps:
- Select the “Review” tab on your MS Word file.
- Select the “Language” group under it and click on “Translate.”
- Select “Choose Translation Language.”
- Under it, select the “Translate from” and “Translate to” tabs according to your language translation needs.
- Click on “OK” to set it.
If you choose to translate an entire file, select “Translate Document.” Choose “Translate Selected Text” otherwise if you just want to translate a portion of text. You can also right click on the selected portion and choose “Translate’ from the drop-down menu.
