Hello, I am a beginner in programming and would like to start by learning more about C#. I need software to execute C# programs for Windows 10. Please tell me which ones can be used and how to install the software. Please reply ASAP. Thanks in advance.
Learn Where And How Microsoft Net Framework 4.5.2 Is Used
Some of the software that can be used for learning C# are Mono, Microsoft Net Framework, etc. I would recommend using Microsoft Net Framework since it allows you to develop applications for desktop, laptops, tablets, etc. It has support for other programming languages such as C, C++, Visual Basic, etc.
To install it, we can go to the Downloads page for Microsoft Net Framework 4.5.2
Click on the Download button and download commences.
Once the installer is downloaded, navigate to the Downloads folder and click on the exe file and run it with permissions. It will do the needful for you and once it is installed, you can refer online manuals for how to execute C# programs in Microsoft Net Framework 4.5.2 .
