By Learning About HP PSC 1210 Ink Cartridges
Hi. I am not a computer-related person. I want to learn how to replace the HP PSC 1210 ink cartridges. Please reply ASAP. Thanks in advance.
Hi. The steps to replace the HP PSC 1210 ink cartridges require you to first close the door and in case the access door of the cartridge is open, it should be closed. Then, determine which cartridge is causing the problem and remove it. Then, close the door of the cartridge. Then, remove the cartridge which was causing the problem and reset it. After this, clean the contacts on the problem cartridge. After this, keep repeating the steps to reset and clean the cartridge until and unless it gets completed successfully and towards the end, replace the cartridge facing the problem by unwrapping the new driver and placing it in the slot wherein the old cartridge had been placed. Also, remove the old cartridge from its slot.
Hope we helped.
