I am looking for someone to give me the right direction I need to take to learn embedded software. Which tools and resources would you recommend I procure to get started with embedded software development? What do I need to take notice of when I embark on this journey? How can I climb up higher and get to an advance level?
Learning Embedded Software Design and Development
To start up with Embedded Software design and development, here are some of the tips:
** Learn ‘C’ language perfectly because it is well coding methodology in Embedded systems.
** Learn about Microcontroller and Microprocessors.
** Try to get awareness about all types of software architectures that are used in Embedded Software. Learn more about Real Time Operating Systems(RTOS) internal and working procedures.
** Try to develop your own coding in ‘C’. Learn the tools for whatever chip you are going to use.
** Learn Assembly level language programming.
