By Learning How To Connect To XFINITY Wi-Fi Hotspot
Hi. I would like to know how to connect to XFINITY Wi-Fi hotspot. It is urgent and the solution is needed on an urgent basis. I am a Windows XP user. Please reply ASAP. Thanks in advance.
Hi. To learn how to connect to XFINITY Wi-Fi hotspot, click on the icon of Wi-Fi which appears on the desktop. A list of all the nearby networks which are available for connections will get displayed before you. Then, to get connected to the private network, click on the name of the network and click on the connect option. Enter the security key if asked to verify and get connected.
Then click on the Wi-Fi icon and then select the properties option. When the dialog box for the properties opens up, select the wireless networks tab. Then, under Preferred networks, select the name of the private home network. Then, under the preferred networks again, select the XFINITY Wi-Fi network and bring it just below your private home network. Then, close the window. Now, whenever you are home, you can connect to your home network and if not, you can get connected to the XFINITY Wi-Fi network.
Hope we helped.
