D Morgan
10 points
Posted on - 09/18/2016
Hi. I open my favorite websites and every time I try looking for them again, I never find them back. How to create shortcut to website so that I can access them as and when I want to? Please reply ASAP. Thanks in advance.
G.Adam
10 points
By Learning How To Create Shortcut To Website
Hi. To learn how to create shortcut to website on Google Chrome, enter the URL of your favorite website and click on the icon which is in the shape of a tool on the right of the screen. Then, click on tools and select the option to create the application shortcuts. Next, a dialog box will appear asking you whether the shortcut should appear on the desktop, taskbar or the start menu. Select from the above three options and click on create to create the shortcut so that it can easily be accessed. Using Firefox, firstly format the size of the window so that the computer’s screen as well as the browser’s window can appear on the same screen. Then, click on the icon shaped like earth, move it to the desktop and then release the cursor of the mouse.
The shortcut will get created on the desktop. Item from the bookmarks as well the library menu can be moved to the desktop by dragging them.
Hope we helped.
Creating a shortcut to your favorite website on your web browser is easy and every web browser supports this functionality. Creating a shortcut to a website means adding it to your bookmarks. To add a website to your browser’s bookmarks, first, visit that website on your browser. Once the page loads, you can now add it to your bookmarks.
In Opera browser, click the heart icon at the end of the address bar to add the site to the bookmarks. Another way is to press CTRL + D on your keyboard. If you are using Mozilla Firefox, click on the star icon located on the upper right corner of the screen just before the clipboard icon to bookmark the page.
The same with the Opera browser, you can also press CTRL + D in Mozilla Firefox to bookmark the page. On the Google Chrome web browser, just like with Mozilla Firefox, click on the star icon on the upper right corner of the screen to bookmark the page. It also supports the CTRL + D shortcut to bookmark the page.
