E.Robe
10 points
Posted on - 08/19/2016
Hi. It is becoming really unsafe to allow kids to surf the net these days. Being a working woman, I would like to know how to limit Internet access if that is possible at all. Please reply ASAP. Thanks in advance.
Learning How To Limit Internet Access In Easy Steps
.Hi. Limiting the sites which the child can access in your absence can sure be limited. To know how to limit Internet access, you can use sites such as Bitdefender parental control. To use it, first, open the web browser and type the website my.bitdefender.com in the address bar. Next, sign up and then log in the account using your credentials. Next, click on parental control so that the dashboard can be accessed. Then, select the profile of your child which has been created by us using the details you provided. Then, click on the arrow on the panel of the web so as to access the window named Web activity. Then, click on schedule.
You can then select the sites which need to be blocked by you and also the time interval for which it needs to be blocked. The internet access will be blocked completely if you select the block all option and in case a new selection needs to be started, click on allow all option. When all the modifications are done, click on save option.
Hope we helped.
