Learning How To Open Event Viewer In Windows 7
Asked By 210 points N/A Posted on -
Hi. I am not very hands on with using MS Windows 7. I need to open the event viewer. How to open event viewer in Windows 7? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #112698
Hi. To learn how to open event viewer in Windows 7, first click on start and in the search box type the event viewer file extension and click on enter. Next, click on yes if prompted by UAC when you are logged in as an administrator. Click on the event log to view all the events which have been listed in the middle pane. For more options, you can right-click on the event log. To view the details of the event, the listed event either needs to be clicked or double-clicked.
You can also try typing Event viewer. Using Windows Utility tab also, the program can be opened by using WinBubbles. The events can be monitored on the computer by changing the settings on the local security policy which needs to be monitored. Then, click on the Windows logs in the event viewer.
Hope we helped.
