Learning the software Adobe Premiere CS6 and in-depth training
50 points
Posted on - 04/20/2015
I am just learning ways to edit in Adobe Premiere CS6. Can you provide me instructions on how to edit the display of columns? How can I rearrange the columns and how can I change the width of the column? How can I sort by a column? Please show me how to add column in my project? What are integer columns? What are the different types of columns that I can use in my project? Can I change this in a list view type columns? Please expound the uses of the mentioned options above and can I properly utilize and use it in my projects?
Thank you!
