Hi!
I want to know more about turn-tables. I want to know Rega RP3/Elys2. What are the specifications of this turn-table? What are the benefits of using this for any disk jockey? Is there any way that I can connect this to my desktop computer? What are the ports available for this? Does it include any jacks to connect it with my desktop? How much is this if I’m going to buy it? What are the system requirements I need to meet in making this work with my desktop or laptop? What is 5th Symphony in this?
Learning turn-tables and its magical effects to computers
Hello Debra!
Here are the specifications of Rega RP3/Elys2.
1. Â 24 V noise motor / float glass platter
2. Â Double-braced plinth
3. Â Precision main beating
4.   Elys2 MM cartridge
5.   RB303 tonearm
Please be informed that we cannot directly connect this to our laptop or desktop. You can connect this to your mixer or receiver and then connect the receiver to your sound card in computer. The benefits show perfectly with any DJ’s not to regular user. However the best feature of this device is that it captures less noise than any turntables while twisting it. It minimizes vibration and magnetic induction. With this you will hear perfect turns and twists while playing with it. The price of this turntable will cost you from $895 to $1,195. There are no system requirements for this turntable. As long as you connect it with your receiver and plug it to your computer then you’ll be able to record your own mixes.
